This is about my ’57 35HP Johnson, but I suppose the question could be about any old engine: is there a correct, recommended way to hold the flywheel / crank from turning while torquing the nut? In my case it’s 65 ft.lbs., but no matter…the question remains: Is there a right way to hold the flywheel / crank in place while applying the torque?
There are automotive tools that lock into a flywheel’s ring gear. Depending on the exact design of the tool, they will often fit smaller, outboard ring gears. If so, they are a little less awkward to use than a stretchy feeling strap wrench. That being said, most of the time I use a strap wrench…..but that’s mostly because my engines are a little smaller and don’t usually have a ring gear. If I did a lot of RD/Bigtwin stuff still, I’d be using the ring gear flywheel holder. They look something like this:
