Home Forum Ask A Member ^0’s Evinrude 3hp
  • #4615
      Hi all,
      I have an Evinrude 3hp I ran the other night and it has an issue. I ran good for a couple hundred feet , but the sputters and quits, unless I pull out and push in the choke until it clears. it does very often. I pulled the card and didn’t see any obvious debris. I have new gas and good oil. I did find that the low speed needle was only set a half turn out.
      Any help appreciated,
      Jason
      #39167
      fisherman6
        What speed are you running the motor at when it sputters and quits? It sounds like it’s fuel related for sure being it takes off again with a blip of the choke. Does this motor have knows for high and low speed or low speed only?
        OldJohnnyRude on YouTube
        #39168
          check the gas cap vent and filter.
          #39185
          david-bartlett
            The fuel filters in the tank will plug, often near the bottom and the problem will often show up when the gas is low in the tank. It may work fine with a full tank. Take the filter out and clean it.
            #39191
              The engine has low speed only needle. It happens at 1/2 to full. Anything lower and the motor quits. I will check the tank filter, but it might not be there as the moor has a rubber fuel line from the tank, not the traditional copper line.
              #39195
              fisherman6
                If the tank vent is open and the filter is not plugged up, it seems most likely this is a carb issue. Make sure all the gaskets are in good shape too but my next recommendation is to pull the carb off again. You stated you didn’t notice any obvious debris in the carb when it was off. There is a high speed orifice screwed horizontally into the bottom of the carb bowl behind the drain screw. It requires a special tool or a slightly modified straight screwdriver to remove. These can become blocked or partially blocked and that blockage is invisible unless the orifice is removed.
                Since your motor will not stay running at all at lower throttle settings, it seems likely you also have some blockage /restriction in the low speed circuit. These can often be cleaned without oulling the Welch plug on top of the carb but jot always. If you completely remove the low speed packing nut and needle you can use aerosol carb cleaner with the straw to spray directly into the low speed orifice. Also, there are small holes in the top of the carb throat directly below the Welch plug by thr butterfly. Spray carb cleaner thru those holes and make sure you are getting cleaner coming out at the opposite end of the low speed circuit. If you are not getting flow thru you will end up having to remove the Welch plug. Make sure the needle packing is holding the needle firmly and not allowing any air to leak by when running. I would suggest buying a carb kit and replacing the float needle and seat and the float if it is still a cork one.
                The initial setting for the low speed needle should be around 1.5 turns out from ‘lightly’ seated. Itmis possible there maybbe another issue, but the carb seems like the next logical step considering the symptoms. I hope this helps.
                #39209
                  I have a Johnson 3 with kind of the same issue. It’s a ’67, so it, too, only has a low speed needle. Runs poorly to not at all at lower speeds. (Mine is also hard to start….is yours?) Carb is perfect, ignition is perfect, everything seems perfect……except maybe the compression. I don’t really have a bench mark to go by on compression; but I suspect this may be my problem, since it had a previous history of overheating. I have yet to get back to it. Maybe somebody can post some good compression numbers, so we BOTH have something to go by…..
                  #39216
                    75-85 psi. They’ll run at 60 but not well.
                    #39231
                      OK, well I’m not sure of anything right now. Sounds like the engine runs lousy at all speeds, but won’t run at all at low speeds, correct? The engine isn’t going to idle with the needle set at only 1/2 turn out from gently seated though.
                      Tell us more about how it "sputters and quits", kinda sounds like it may be dropping a cylinder. Have you done a good spark test, or perhaps you might want to try the inline neon spark testers while the engine is running. I suppose, as always, I should start at the beginning with new plugs though.
                      Can you post a video of the engine misbehaving?
                      Always start with the simple things, because most problems are simple.
                      #39272
                      cajuncook1
                        Mercman, those little 3hp motors are great engines, but an evaluation of a motor should always consist of first compression, then spark(ignition) and then fuel delivery(carburetor).
                        What are your compression numbers? If you have not check compression please borrow or get a loaner from AutoZone or Napa..etc.
                        If you have low compression, a good igntion or a cleaned dialed in carburetor is not going to improve running.
