Home Forum Ask A Member 120 Hp Merc Inboard/outboard
  • #2283
    deltonmike
      Sorry I know not an outboard question
      I an replacing an engine in my pontoon, 120 Hp Mercruser Mer. outdrive. There are adjusters on the motor mounts how do I adjust them is it necessary and how close to they have to be.
      #22151
      wiscoboater
        The adjusters are set with an alignment tool. They are for adjusting engine crankshaft pitch and angle to prevent wear or failure of the gimbal bearing. If you do not have the proper alignment tool and are not versed in it’s proper usage, it is best to take it ( the boat) to a professional. Install the engine, bolt it down, and take it in to have it adjusted BEFORE reinstalling the outdrive. Tell the boat shop you would like them to align the engine. Failure to get this adjustment right will cause severe damage to the coupler, gimbal bearing and u joints.
