Home › Forum › Ask A Member › 1913 rowboat motor
- This topic has 8 replies, 4 voices, and was last updated 5 years, 8 months ago by
Tubs.
June 2, 2020 at 10:04 pm #204844
I’ve been tinkering with this thing off and on trying to get it to run. It’ll run 10 seconds top VERY intermittently. I decided to tear it all down as it seemed to have a slight knock when it ran. It seemed to have a lot of unburied fuel oil mix inside the piston. Cylinder is pretty smooth. There seems to be about 1/4” of vertical play in the crankshaft, almost like it should have a bushing under it. Are their any people who make parts or are there any parts that fit other motors that work in these engines? Mainly rings I guess. And what about the up and down play in the crank? Is there a way to adjust this? I know of a member who told me a piston for some speedsters also fit a John Deere tractor and were available. Was hoping this may be the case with these engines. I know there are a lot of em still running, just wondering how people keep them running all these years?
It's a jungle out there.
June 3, 2020 at 2:15 pm #204890If it has Carburetion, Compression and Ignition, it has to run.
So said a mechanic friend reflecting his years of experience.
Wet spark plugs indicates fuel is getting from fuel tank to
cylinder. Compression in 1913 was no where near 10 to 1 so
even low compression reading motor will probably run even with
reduced power output. 2020 minus 1913= 107 years…probably
time to clean points and check coil and wires. Get out your ignition
file, heat shrink tubing and VOM Soldering skills may come in handy.
Wear issues and missing or broken parts are normal for century old
mechanical devices of any kind. You may have to expand your knowledge and skills to deal with them.
Cylinder wear MAY only require honing. OR more serious work,
New rings, if required, have to be correct size for cylinder bore and
piston groove.
Each old outboard is an adventure having its own individual learning
curve. Good Luck and have fun.
The REALLY old outboard group exist in a corner of the hobby with
its own network of sources and knowledge along with some skills
seldom encountered in 21st Century.
Louis-
This reply was modified 5 years, 8 months ago by
green-thumbs.
June 3, 2020 at 9:42 pm #204904I believe I’ve found a problem! See picture below. Anyone know where I may find a flywheel for me RBM? Seems like this could allow it to start but not stay running, any thoughts?
June 3, 2020 at 9:43 pm #204905Ok I’ll try again
June 3, 2020 at 9:45 pm #204907How come when I go to resources, nothing happens?
June 3, 2020 at 10:51 pm #204911It helps to be a magician/machinist on those old timers.
dale
Happy wife happy life!
June 4, 2020 at 10:40 am #204927
Tubs.
Tubs.
Tubs.
Tubs.
Tubs.
Tubs.
This reply was modified 5 years ago by
Tubs.
June 4, 2020 at 12:30 pm #204935I’ve been sure to keep a hot battery and bought a new buzz coil. Cleaned pints and plug. I’m thinking fuel also tubs. The starting procedure says push the poppet up til gas drips out. I’m assuming this is just to fill the bowl? When I do this, and then it tries to start or occasionally starts and dies, I’ve noticed if I push the poppet up immediately after it dies, more times than not I have to hold on it a few seconds to get the “drip” again. Is this normal? I’ve tried every scenario, opening the bottom knob a little more to introduce gas. But then it seems to go from starving to flooding with just a tiny increment. Also, is the flywheel cast or can it or should it be welded? I had read somewhere if the flywheel key is worn really bad on these older motors that it would cause them not to run, is this only true on certain motors? Lots of questions I know, and I’m typically a do it myself kinda guy but I’m stumped
June 5, 2020 at 2:21 am #204970
