Home Forum Ask A Member 1935 Johnson Aero built 300 fuel mixture
Viewing 10 posts - 11 through 20 (of 32 total)
  • #57260
    hutch1935
      One more question on the left hand side of the lower unit there are two plugs one says vent and one says drain what are they for?
      #57261
      hutch1935
        #57262
          Filling the gearcase.
          Remove both. Fill from the bottom (drain) until it exits the vent. Install vent screw with new washer, remove fill tube from drain hole, and install drain screw with new washer.
          Done.
          #57276
          hutch1935
            Fill with grease or Molly?
            #57277
            hutch1935
              I found three of the similar-type plugs neither one of them can take a washer it’s just a plug that goes in one at the very bottom of the unit that I believe I was told in one post fill with grease and in those two that are on the side of the left lower unit and neither one has a space for washers just the screw type plug that goes in . By the looks of it I’m assuming that’s where the plunger type impeller is?
              #57283
              hotrod
                The DRAIN plug is removed to drain the cylinders of water before winter.
                The VENT plug is removed while filling the lower unit with grease. When grease starts to come out of this vent hole, the gearcase is full.
                The unmarked plug to remove for inserting grease is on the lower left side of the gearcase cover, just ahead of the prop.
                #57285
                  quote Hutch1935:
                  #57294
                  hutch1935
                    Great info. Thanks again
                    #63535
                    kevinrude
                      Follow up question on this thread: I also have a Johnson 300. I notice the oil specs above call for SAE#40 to mix with the gasoline. Is it OK to use standard marine two-stroke (TCW) or is SAE#40 appreciably different?
                      Thanks!
                      #63541
                      hutch1935
                        I just use exactly what it calls for then I have no question as to whether I’m doing what’s correct for the motor. I’ve been running exactly what it calls for in mine and it runs better than any of my new machines so I just go with that.
