Home Forum Ask A Member 1935 Johnson Aero built 300 fuel mixture
Viewing 2 posts - 31 through 32 (of 32 total)
  • #63707
      Its not likely that we are done with this subject
      because people keep asking. While some have
      there mind made up others may come here to ask
      because they would like to run less oil. There are
      a variety of concerns they may have that others don’t.
      The main one is to show those that aren’t fans of
      our old motors that we have the same concerns as
      they do about the air and water and we aren’t using
      and more oil that most modern 2 cycle outboards.
      Some time ago, to learn if you could run less oil in
      the earlier bushing motors, I built this motor from
      parts from at least 4 other motors. The timer,
      flywheel, exhaust are from a 28. The power head is
      a 29 I got from Doug Penn. I’m not sure where the
      rest of the parts came from. It calls for 3/4 of a pint
      or 12 oz per gallon. The oil I used was Pennzoil full
      synthetic at 3 oz. per. gal. My thinking was by
      reducing the oil by 2/3 it wouldn’t take very long to
      know if it this was fact or fiction. That was 2010.
      I ran almost 50 gallons of gas through it that summer
      trying to blow it up. I can’t say how much gas I’ve run
      through it up till today but it still pushes the boat almost
      20 mph. I have been using that mix in most everything
      I have ever since.
      Westwind has a valid point about the oil sealing the
      main bearings. 3 oz. isn’t enough for my Pal’s, Ranger,
      or my Sea King Midget. They need 4 oz. to make the seal.
      Everything else I’ve run so far does fine on 3 oz. per gal.
      I’m not looking to change the world. Just tell those who
      would like to run less oil that I do. Then they can decide
      what would be best for them.
      #63819
        I guess the video link wasn’t working.
        I think this one will.
        https://www.youtube.com/watch?v=5GRrmslnz2A&t=1s
