Home › Forum › Ask A Member › 1953(54?) evinrude big twin 25hp carb
- This topic has 11 replies, 6 voices, and was last updated 4 years, 1 month ago by
JACQUES.
February 4, 2022 at 7:01 pm #253990
Can’t get to run for more that a few seconds. Magneto, pressure tank, and carb rebuilt, new plugs and wires. After a number of unsuccessful starts, fuel starts dripping pretty good from carb intake. Pulled carb back off just to double check float position, pin seating, etc.. noticed that when I let the throttle valve ease back to idle, it covers 2 of the emulsion orifices,(not sure what to call em, the little holes under the welsh plug) pic#1. If I let it snap back, it only covers about a quarter of those holes. Pic#2. This throttle valve is a complete disc (pic#3) Pic #4 is the throttle valve from a 1955 big twin 25hp, flat spot and a hole. Question is: could the valve covering those holes be a problem? Running out of ideas! Spark is good, compression 110 top and bottom.
February 4, 2022 at 8:00 pm #253995the top holes are just for the idle circuit of the carb . hopefully you have replaced a plug over those small holes … (sorry had to ask)
if the carb drips the float is not adjusted properly. is the float level with the carb body when flipped upside down ? float not upside down is it ??
carb float is just like a toilet bowl tank float. full=> stops the inflow
did you do a proper blow test on the carb before installing it to confirm the inlet needle shuts the inflow of air 100%
did you download yourself a copy of the bible Johnson service manual from Garry’s drop box ??
February 4, 2022 at 8:07 pm #253997Over choking might be the cause of fuel drip.
February 4, 2022 at 8:28 pm #254005Welsh plug in👍 Float level👍 Blow test, shoulda thought of that thx. Thx for tip on manual.
obtw not over choking but thx
February 6, 2022 at 12:05 pm #254097I have noticed all of my Big Twins will leak from the carb when the motor is tipped up (to bring the prop out of the water). Seems just a normal feature of the design. I usually disconnect the fuel line which does minimize the drip. Inherent in the design I think.
February 6, 2022 at 7:13 pm #254167I had same issue on a RD14,replaced crankshaft seals and problem was fixed.
This reply was modified 4 years, 1 month ago by
stanley.
February 6, 2022 at 8:01 pm #254169Stanley. I don’t see your post yet but I got the email. Yes, hard to start, only sputters for a few seconds.
February 6, 2022 at 8:58 pm #254170Stanley, I usually also replace the crankshaft seals on RDs but to date have not stopped the leak. My boat is in the water all summer which gives even a small leak a lot of time to show. I think the leakage is from the carb throat. Can’t see that changing c’shaft seals would affect the carb – but maybe so. Anyway disconnecting the fuel line does help a lot.
February 6, 2022 at 9:47 pm #254171did you try the blow test … did you change needle and seat ? how was the float … old cork soggy or new plastic one ?
February 6, 2022 at 10:04 pm #254173I’m wondering if the carb with the full butterfly was used in competition. When I raced, all of the Stock outboard engines were required to be equipped with a full butterfly valve. The holes that exist below the area that must be covered by a Welch plug are low speed, idle fuel orifices. If the butterfly completely closes the carb rear throat, no air will flow, and no fuel will be drawn into the engine thru the idle ports. Just a thought. Try the butterfly from the other carb. Just a thought. R.T.
