Home Forum Ask A Member 2hp knock
Viewing 8 posts - 21 through 28 (of 28 total)
  • #236367
    free1986
      It may be a trick of the photo, but it looks like there is a crack in the connecting rod from the right side cap bolt hole toward the bearing? Not sure that it would cause a knock, but it doesn’t look encouraging.
      #236376
        Good eye! I see that also, sure looks like a crack…
        #236378
        jamesdavisiii
          Looks like a crack where the rod bolt goes in.
          #236382
          mike n
            oh man i’m embarassed. i missed that one. cant look at it now. i’ll check it out this weekend
            mn
            #236383
            mike n
              i guess it could distort the bearing sleeve when its torqued
              mn
              #236850
              mike n
                I ordered a new connecting rod,and bearings.just waiting for them to arrive. Anyone know torque specs for connecting rod,head bolts,flywheel or where I can find the specs. Thanks
                mn
                #236897
                  This chart shows 5 – 5.5 Ft Lbs but I’d go with inch pounds for better accuracy, 60 – 65. Since a 1/4″ drive socket seldom fits on the bolts without grinding it down, I use a screwdriver with a square shank and snug them up with a wrench on the shank before folding the locks over. Since I can’t get a torque reading this way I just guesstimate it.
                  Torque-Chart
                  #237008
                    Often wondered why OMC used those little hex head screws that you couldn’t get a socket on…Trying to apply proper torque with a screwdriver bit is tough, be sure to replace those lock tabs also…
