Home › Forum › Ask A Member › 302302 TN Drive Shaft Seal
Anyone have a pic of one, or one handy?
This one Chris?
http://www.ebay.ca/itm/M7-OMC-Johnson-E … 1740302112
Where does that piece go on a TN? Can’t remember ever seeing one.
Something is wrong? Mumbles you are showing something from Ebay that is different than ME is showing. They have it as just a regular seal. Like a D/S seal that Chris may be asking for. Who has it right?
Dan in TN
Yeah it is just a normal oil seal. Not sure what that guy has! lol
That thing on e-bay is part of an OMC Factory Special Tools Seal Puller. Maybe the one to remove the 302302 seal.
You nailed it Frank! Didn’t reconize it without the other part. You don’t see those much anymore.
How did it work? I assume that piece threaded in the bore of the seal, then another bolt pulled it, ?
Right. Not shown here is the spacer sleeve that goes between the big washer and housing holding the seal. Tightening the nut down pulls the seal out.
image hosting
Did that setup work well Frank? Id like to find a kit one day.
Note the upper one in the picture is broken. That was their downfall. Too brittle.
OK
