Home Forum Ask A Member 303345 prop shaft SKF equivalent
Viewing 10 posts - 1 through 10 (of 22 total)
  • #272998
      anyone  have the SKF # equiv. ??     303345 are $$$$$$ 🙁
      #272999
      Steve D
        crosbyman, I have it in my notes as CR/SKF 5605
        #273000
          ok will check  them out
          #273001
            found #4995   at .500 x .999.x .313      think .500 shaft would be to thight  ???    .313 height  is nice            but    2  x..250’s could do also if using cr5605
            #273004
              actually it is skf 4996 not  4995…could not edit 🙁  🙁   🙁
              #273019
              Evinrude 25
                Hello,
                SKF seal
                Inside Diameter: 12.7mm = 0.5 inch
                Outside Diameter: 25.37mm = 0.999 inch
                Width: 7.95mm = 0.313 inch
                303345 – Seal –
                1 Inch OD
                I.D – 0.554
                O.D. – 1.0
                Height – 0.375
                https://www.marineengine.com/newparts/part_details.php?pnum=OMC0303345
                I think it is a typo for  the ID. 0.554 but the original seal 3/8″ thick vs 5/16″ thick of SKF. Does it matter?
                #273020
                Evinrude 25
                  CR SEALS (SKF)
                  CR 5605  Single Lip Oil Seal – Solid, 0.554 in Shaft, 0.999 in OD, 0.250 in Width, CRW1 Design, Nitrile Rubber (NBR) Lip Material
                  SKF 4996 / 0.5X0.999X0.313 CRWA5 R – Oil Seals
                  1/2″ Shaft Dia; 0.999″ Housing Bore; 5/16″ Nominal Width; Nitrile Lip; Solid Seal; 5/16″ Actual Width; Spring Loaded; 2 Sealing Lips; Carbon Steel Garter ..
                  CR5605 is closer to OEM 0303345 but its thickness is  1/4″ vs 3/8″ of OEM (0303345).
                  #273023
                    ok will try local shops for cr 5605
                    #273025
                    SonofaBeach
                      My Notes also indicate a National Seal equivalent #473546.
                      Note however that National Seals are typically not Stainless Steel.  Maybe not the best choice for a salt water motor…..but typically are pretty inexpensive and available at O’Reillys as well as numerpous other places.  Good for a motor that won’t get used much?
                      #273030
                        OK checked my parts zoo and found a CR5605 !!!  I rember coating some a few yers ago with latex glue to protect against rust .  (Memmory lapse!!)
                        Should keep notes like Steve D  🙂
                        thanks all for replies
