Home Forum Ask A Member 3036 (JW) oil seals
  • #5627
      I pulled the drive shaft out of the gears while doing the impeller 🙁 ….I’ll have to work at it to reinsert it but…..
      assuming the gearcase oil seals are gone (oil wise) is is it ok to just refill the gearcase with John Deere corn grease seing this is a non shifting gear case ?
      #46959
      lindy46
        You’re talking about a 3hp Johnson JW series? Takes 80-90wt marine gear oil. To reinsert the driveshaft, shine a light down and move the gearcase around until the pinion gear is centered on the hole – then re-insert the shaft.
        #46960
        retiredoz
          Or hold the gearcase with the propshaft pointing straight down. Worked for me, thanks, Frank.
