Home Forum Ask A Member 305446 distributor belt
  • #224365
    JAN ADALBERON
      My 58′ “fat-fifty” needed a new distributor belt and I searched Ebay and marineengine.com for a new one. Found the price quite stiff, and as I work with spare part / machine elements I did another search for tooted belts with 3/8″ pitch and 3/8 with, 86 teeth.
      Found this :My 58′ “fat-fifty” needed a new distributor belt and I searched Ebay and marineengine.com for a new one. Found the price quite stiff, and as I work with spare part / machine elements I did another search for tooted belt with 3/8″ pitch and 3/8 with, 86 teeth.
      Found this : https://shop.polybelt.com/322L037-Black-Rubber-Belt-3-8-inch-Wide-86-Tooth-B322L037BNG.htm
      It’s a perferct match !
      The problem is that you have to make a purchase of at least $24.99 ( 5 pcs ) so you should have some friends who also need a new belt – or a lot of motors 🙂
      Sorry for the bad english – I’m form Norway
      • This topic was modified 5 years, 3 months ago by JAN ADALBERON.
      #224369
      lindy46
        Good find if they are the correct ones. So buy 5 of them, keep one as a spare and sell the other 3 for $10 each. You get 2 free belts and your buyers get their belts a lot cheaper than the $78 Marine Engine charges.
        #224374
          Thanks Jan for posting the tip. I already knew about Polybelt, but didn’t know they now have a minimum order. Still a good deal. They also have the OMC generator belts.
          #224410
