Home Forum Ask A Member ’38 Water Witch
Viewing 10 posts - 11 through 20 (of 27 total)
  • #36255
    mike-stroz
      Just got around to trying it out and it’s getting gas, the cylinder is loosening up (kind of tight before), but not getting spark. I think I’ll clean the points and try again tomorrow.
      #36315
      mike-stroz
        Tried cleaning the points and I got a single pop, and then nothing. Any ideas? Maybe stuck reeds or a bad plug?
        #36368
          • This reply was modified 7 years, 4 months ago by Tubs.
          #36383
          mike-stroz
            I think they were a little stuck from sitting for so long, but it seems good now. I got a new spark plug and it’s running now, and pumping water good, but no matter how I twist the fuel mix, it won’t run right. Any leaner and it backfires, any richer and it stumbles and wants to die.
            #36386
            mike-stroz
              The exhaust tube is also really hot, as in boiling any water that splashes on it. Is that normal?
              #36412
                • This reply was modified 7 years, 3 months ago by Tubs.
                #36423
                  quote Tubs:
                  Remember this when handling the motor after running.
                  Ouch! That looks really painful Tubs and it’s in a part of the hand you use all the time. Ouch again.
                  On the bright side, I bet it made you really smart really fast! 😀
                  #36425
                    #36433
                    mike-stroz
                      Ok, I think I found the culprit. There was a HUGE air leak behind the carb, so I ordered some new gasket material make a new one. I’ll try to make sure not to touch the exhaust, or the spark plug for that matter. I learned my lesson on my crappy Elgin… Those things hurt…
                      #40397
                      mike-stroz
                        Just got back to the Waterwitch, I’ve just been so busy lately. I took apart the carb since it still wasn’t running quite right even after I fixed that air leak. Took apart the float bowl and a whole bunch of rust poured out… There was a little surface rust in the tank, but I didn’t think too much of it… Oops… Now it runs fine after I tuned the carb (I also didn’t realize there were 2 jets, I thought the other one was a drain…). Now my friend’s dad wants it to power his little 10′ aluminum rowboat.
