Home Forum Ask A Member 4425 Coil
  • #33108
    Randy in Tampa
      Sent you PM…. 😎
      #33111
        Randy,
        Sent you a PM.
        #40745
        chunk
          Having problems locating these coils as well. Has anyone ever rebuilt a coil?
          #40796
            Are you sure the coil is bad? If so, is it possible to put another coil on those horseshoe laminations? The common OMC two-cylinder coils are only about $15-20.
            #40812
            chunk
              When I test from the spark plug wire connection to ground i get nothing. When I test from the wire that goes to the condenser to ground i get continuity. According to you tube my coils are dead, right? Does anyone know where I could find these coils?
              #40825
                • This reply was modified 7 years, 4 months ago by Tubs.
                #40878
                cajuncook1
                  Did you try Doug Penn?
                  #40892
                  Randy in Tampa
                    Tubbs, I did not receive a PM from you, I guess you didn’t receive my PM I’ve been trying to let you know I have some…. 😉
                    #40901
                      #40924
                      Randy in Tampa
                        quote Tubs:
                        That’s dated last March Randy.
                        I cant remember yesterday.
