Home Forum Ask A Member 54Evinrude Big Twin crankcase
Viewing 10 posts - 21 through 30 (of 39 total)
  • #31654
    olcah
      Fleetwin, If there was positive pressure in front of the reed plate, seems like it would cause bubbling at the bearing o-ring groove. Last fall I turned my Johnson motor over with a wrench with WD40 covering the top of the seal. Bubbles came up through the vertical slot. I will change the pressure valve for the tank.
      #31661
        That’s nice and clean inside!
        [/URL]
        #31689
          here are some more pictures I uploaded for Charlie:
          Well, I am confused, as usual…This engine seems to use a combination of the oring around the upper bearing and the vacuum drain systems…
          My question is: does that vacuum groove in the crankcase go into the oring groove? Kinda hard to tell by the pictures. If so, this seems like an engineering "mistake". The dark wet surface on the crankcase shows pretty clearly where the leak is, sure does not appear to be a crankcase sealing problem. I will have to look closer at the pictures…
          #31696
            OK, here are some more pictures of the crankcase drain passages on Charlie’s engine:
            OK, it is hard to see, but the groove in the crankcase does extend into the groove where the oring was…Hard to see, but the little vacuum port is in that groove where the oring was…In my feeble mind, I’m thinking that oring does not belong there. Having the oring in the groove kinda plugs up the vacuum port and system efficiency. So, to me, having the oring in place was either a manufacturing or engineering oversight, I don’t think this powerhead has ever been apart before. I’m guessing this engine is in such nice shape cuz it was rarely used due to the constant oil fouling of the mag plate…
            What do you guys think? I wish that this crazy system was used in conjunction with the conventional oring sealing. In other words leave the crankcase groove above the conventional oring groove, along with the vacuum port. They could have even added another circular groove around the upper bearing as well…
            #31862
            olcah
              Well, the plan is to put the motor together without an o-ring on the top bearing as that is apparently the latest configuration. Many thanks to all for the advice and especially to fleetwin and F. Robb.
              VR
              Charlie
              #32400
              olcah
                Bolted the crankcase together this morning then removed the head as one spark plug thread is stripped. The port side of each bore is shiny smooth. The starboard side of each bore has lots of shallow scratches. I really do not want to open the crankcase again but is condition of these bores common?
                Thank you.
                http://i77.photobucket.com/albums/j66/c … 1456167090
                http://i77.photobucket.com/albums/j66/c … 1456167094
                #32404
                  There should not be an o ring on the top bearing for that model. Many times, one gets installed when they are opened up.
                  #32406
                    quote OLCAH:
                    Thank you.
                    Well, can’t really see much in your pictures. Minor "scratches" are usually not a cause for concern, is there any evidence of aluminum scuffing on the cylinder walls? The intake bypass covers can easily be removed on the port side to get a closer look at the rings/piston skirts. Removing the exhaust cover shouldn’t be too tough on a fresh water motor, but cleaning up the gasket surfaces/carbon is time consuming, but removing the cover will give you a better look at the exhaust side of the pistons/rings.
                    I usually use some fine emery to clean up and remove the glaze from the cylinder walls. A little unethical, but works just fine.
                    Again, I can’t make any judgements based on your pictures because the cylinder walls don’t show up well. Take some more pictures if you can…D
                    PS, you can see the lower exhaust side of one piston just by flipping the powerhead on its side and looking up into the exhaust chamber if the powerhead is still off the exhaust housing….
                    #32424
                    olcah
                      Here are more photos.
                      http://i77.photobucket.com/albums/j66/c … 1456191343
                      http://i77.photobucket.com/albums/j66/c … 1456191339
                      The scratches catch a fingernail drawn across. I estimate they are 0.005 deep. Does this seem ok?
                      #32425
                      david-bartlett
                        Charlie,
                        I am thinking(hoping) that the pictures make it look worse than it is. Any idea of compression numbers yet? I think that will tell you what you need to know.
