Home Forum Ask A Member 55 RDE-17, 25 hp, Power Head O-rings, etc
Viewing 5 posts - 51 through 55 (of 55 total)
  • #79469
    fisherman6
      I usually test at 10 psi. If it holds 10 move down to around 6 and see if it still holds. In my experince so far with OMC split gearcases, if they hold 10, they’ll hold 6. The shift rod O-ring is usually the first thing to start leaking on these. Sometimes that is the only thing that is leaking if there is a leak. Other gearcases may not behave this way, but most of the ones I work on are the split 2-piece OMC.
      OldJohnnyRude on YouTube
      #79470
        Ben, not sure I’m following the logic. If a gear case holds pressure
        at 10 psi, why wouldn’t it hold at 6 psi?
        Thanks.
          Depends on seal orientation. More pressure can actually help a leaky seal hold.
          #79481
            quote Chris_P:
            Okay, now I have my brain back on track, lol.
            Makes perfect sense now.
            Thanks.
            outboardnut
              quote Wyo307:
              Looking great so far! If you run into anything that is broken and don’t have the parts shoot me a message, I have a bunch of misc parts laying around from when I rebuilt mine. I just need to paint mine and it is good to go. Runs great though!
              Wyo307 You have a private message and I sent you an email —– outboardnut
