Home Forum Ask A Member ’57 35hp carb ?
  • #6131
    jiall2
      I have the carb apart. My nozzle p/n 304601, item # 74 in the parts catolog has washer on the end that sits in the float chamber. I do not see this washer shown in the parts catalog. Does anyone know if this washer is out of place, on my carburetor. Not sure if it is suppose to be there or not. Thanks for any help
      #51240
      jiall2
        This is a Johnson outboard
        #51244
          Technically they are only necessary on the fixed high speed jet models, however I install them on all my carbs I rebuild to prevent issues. It definately wont HURT anything.
          #51248
          jiall2
            I have a new nozzle 304601 and now I’m wondering how far do I screw it in? The washer on the old nozzle seemed to be a stop, the new nozzle has no stop washer Thanks for the help
            #51249
              X2 what Chris said. Your 35hp did not come with one, nor is it needed. The high speed needle adjustment compensates for any leakage around the nozzle. But it’s ok if you put one in anyway.
              #51251
                Screw the nozzle all the way in till it bottoms out.
                #51252
                  They were first used on the smaller models because leakage there could completely negate the high speed adjustment. They felt the larger fuel demand of the big twins could tolerate that leakage. Like the man said, a seal there can’t hurt. It is essential in the fixed jet models. . . 😉
                  #51261
                  jiall2
                    Got it! Thanks for all the help.
                    #51270
                      I like to put that doughnut washer in anyway, but to make it fit, you may have to reduce the thickness of it.
