Home Forum Ask A Member 58 Johnson 35hp
  • #279220
    3milepoint
      58 Johnson 35 RDE 19-C new coils, points, condenser cleaned and redid carb
      Problem, can not keep running, carb set at Factory setting. Starts for 2 seconds
      shuts down starts, shuts down made little adjustments to setting, nothing worked. Got spark
      Could it be the carb.
      Thanks
      Steve
      #279221
      3milepoint
        What is a BBCodes
        #279223
        lindy46
          Check compression and spark. Spark should jump a gap of at least 1/4″ in an open air tester. If compression and spark are good, could be timing is off. You may need to do a link and sync. Make sure carb butterfly just starts to open when the pointer to the left of the follower roller hits the mark on the cam. If not, loosen the cam and adjust to make it so.
          #279229
          3milepoint
            my 58 Johnson has 118 lb compression strong spark top plug lessor on the bottom with a tester
            #279257
            lindy46
              Motor should continue running at idle even on one cylinder. Check link and synch and make sure you’re getting fuel delivery.
              #279262
              seakaye12
                What is a BBCodes
                BBC Codes are (in my humble opinion) an archaic way of formatting posts on a forum or website.  They are rarely used anymore and ARE NOT required to format posts here on this forum.  All the visual Characters that you see above the text entry field accomplish that.
                #279268
                  Try to post a video of the engine running/misbehaving.  I realize it will be too big to fit here, but you can post a link to the video here.
