Home Forum Ask A Member 66 Fastwin not getting full power
  • #278647
    Kevin Johnson
      I’m gonna try one more lower unit. If it still acts up, I’ll pull the powerhead and check it out. I have a spare already removed.
      Currently working on another project; 1950 TN-26.  I need a little victory to lift my spirits.
      #278691
        Once again, please don’t install another gearcase and pull that powerhead off, you may just be confusing the issue and introducing other problems.    You can simply pull the driveshaft out of a spare gearcase and stick it up inside the powerhead to check from messed up crank splines.
        If you decide to run the engine again, please make a video of the engine misbehaving, might be easier for us to get an idea of what is going on here.  Once again, are you sure you don’t have a short shaft engine on a long shaft boat?  Are you sure those props you are trying are OK?  Perhaps you have a couple of props with worn rubber hubs.  I know, an unlikely coincidence, but worth rechecking.  I just don’t want you to go through all the trouble of changing the powerhead only to have the same issues reoccur.  D
        #278700
        Kevin Johnson
          It’s not a short shaft engine. Got it mounted on a typical 14’ bateau (Jon boat).
          This is the fifth running fastwin I’ve owned.
          #278701
            isn’t short shaft  18 inches…   long 20 and x-long 25 ?
            #278710
              OK.  But perhaps there is something wrong with the bottom of the boat, or perhaps some marine growth on it causing the interference/engine ventilation.  Did you add any transducers or other accessories like that that may be causing an issue?
              You have tried a few different props, all give the same issues.
              It is possible that the crank/driveshaft splines are wiped out, especially if this is a salt water engine.  But, again, I’m not there and can’t hear/see what you can.  I don’t want you to rip the powerhead off unless/until you have confirmed this condition.  A few other things to look for….
              The water pump will stop working if the driveshaft stops spinning (damaged splines).  So, perhaps you can tie the boat to the dock, put it in forward and advance the throttle to the point where it messes up.  Now look at the water pump discharge.  If little or no water discharge is evident, this points to damaged splines.  You have tried a few different gearcases, so this would seem to rule out a broken pinion gear or internal driveshaft breakage.
              Again, try to post a video of the engine misbehaving for us….
