Home Forum Ask A Member 80's Johnson 70 hp
  • #178144
    slim60
      Model # J70TLCDC Ser. # J7132550. My son and I were final checking his boat before our trip north. The Johnson 70 stopped pumping water today. We removed the t-stat, still not pumping. Took 8 bolts out of L/U to check water pump but it only dropped 1/4″. Seems to be hung up with shift rod. Is there a clip or screw that needs to come out? Thanks.
      #178145
      dan-in-tn
        If you look at the shift linkage back up top you will see a retainer clip. Pull that clip and push the shift lever toward the port side of the engine. Be sure to support the gearcase while you do this. The clevis pin will release the top of the shift rod and then the gearcase can be dropped. Going to try to send you a link for you to look at.
        #87 is the clip & #69 is the clevis. Hope that helps!
        Dan in TN
        http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1986&hp=70&model=E70ELCDC&manufacturer=Evinrude&section=Cylinder+%26amp%3B+Crankcase
        • This reply was modified 6 years, 9 months ago by dan-in-tn.
        #178148
        slim60
          It helps Dan. Thank you.
