Home Forum Ask A Member 9.9 merc
  • #1988
    eltoquad
      I’m not into modern engines and my brother is wanting to know if it’s possible to bring the H.P. of a 9.9 2011 Merc 2 cycle up to 15 h.p. by changing to the 15 h.p. carb.
      #19888
      legendre
        quote eltoquad:
        I’m not into modern engines…
        Neither are many of the folks here..
        Anyway, have you tried pulling the specs for both the 9.9 and 15hp models? Unless the displacement & compression ratio are the same, then there’s no point in going much further. If they are, then you need to pull parts catalogs and find out just what other differences exist, in terms of valve size & timing, intake & exhaust components, ignition timing and on.
        In any event, you’re asking a lot to expect a 50% increase in HP from just a carb swap.
        #19910
          I’m sure a merc guy will reply with the specifics
          #19929
          Michael Anfossi
            International Member
            I think that this is possible, but check key parts on marineengine.com or boats.net to see if everything else is the same.
