Home Forum Ask A Member !954 Fleetwin Lower Unit Extension
  • #245413
    drifter
      I have a close friend who needs to extend the lower unit on his 1954 Evinrude Fleetwin (7.5hp).
      I need a sanity check as to the parts. Drive shaft – shift rod – housing – extension screw – water tube.
      Is there anything else I’m missing?
      Also, might someone have these parts for sale?
      I (we) very much appreciate all the help, I always receive from this great club.
      Drifter
      #245468
        Well, that seems right…But, you must remember that in order to change that shift rod, the gearcase must be disassembled….So, you may as well plan on resealing it while it is apart and replace the water pump impeller….
        #245497
        drifter
          Yes, already have those parts at hand. It’s just finding the actual 5″ extension parts that seem to be the problem.
          #245505
            Well, there are a few ways to go about finding the parts. Looking for new NOS stuff, will probably be pretty expensive. You should probably start with confirming that your engine is a 1954 and obtaining the proper parts list. There are some differences between the spring mount mid section and the rubber mount mid section that was introduced in 1956. I’m sure the extension housings are the same, but not so sure about the upper driveshaft/water tube/shift rods. Once you have the proper parts list, we can determine if the parts are the same and what model year engines can provide the needed pieces.
            I would look for used pieces, not too tough to find. It may be even more cost effective to find a whole donor engine to provide the needed pieces, perhaps a blown engine with a bad powerhead. It is a bit of a risk, the used upper driveshaft might be grooved excessively in the seal area, but you will probably obtain the whole engine at a pretty low price, worth the risk.
            I would offer to keep my eyes open, but we first need to be sure the upper driveshafts/water tubes/shift rods are the same between the two different style midsections….
            #245593
            Gregory Ciriello
              Hi
              I have the parts you need just salvaged a 1953 Evinrude Fleetwin 7512 have many parts available just go to gcmarinesalvage.com follow the link for parts. if you have any questions let me know. I have a passion to get these old motor back and specialize in hard to find parts. Everything I have is cleaned and inspected check it out
              Thanks
              Greg
