Home Forum Ask A Member A*45 help
  • #9383
    oopzdoo
      I am working on an A-45,1929 3hp. It has one bad cylinder, cracked on the outside from rust buildup . I found a donor motor from a friend that looks almost the same, with a few differences. The rope sheave says "South Bend Ind. USA Johnson NO. b 10309 Motor Company. The pwhd looks pretty much the same. Water tubes root differently and are smaller. Casting #s on the cylinders are one number apart, I assume as they are left and right {port and starboard}. Big diff is lower unit is the earlier style with exposed pump like the a-25’s. Just wondering what this motor is?Second question, Are there any cylinder gaskets around.
      Thanks Dave in N.H.
      #72291
      lyks2tinkr
        Sounds like your donor motor is a Johnson model B. Much earlier than your A45. Which cylinder is bad on your A45? The starboard cylinder should have a compression release.
        If the B is in decent condition you may want to consider getting it running. It’s more than a few years older than your A45.
        #72298
        oopzdoo
          Thanks for your reply. The donor motor is in very poor condition. It was stuck. I freed it an removed the cylinder. It is the port side, no compression release. The casting # on the A-45 is different , so it appears to be a replacement from long ago. For now I will continue on the A45. I’ll try not to ravage the donor for maybe a future project.
          Thanks Dave
