Home Forum Ask A Member A25 Gearbox
  • #3384
    rapier
      All the images of A25s I see on the net have a different shape gear case to the 1926 s/n 33562 A25 I have. Alarms bells are ringing, as the midsection of this is bronze and the gearcase is the same design as the A35/45 and I wonder if this is a bitsa. Did the A25 design change in the later years of production? Pics of the motor below.
      The reason for my asking is that I need a cylinder (has blown / corroded waterways) and need to be sure that I get the right version.
      https://picasaweb.google.com/1118523892 … directlink
      #30099
      stanley
        My A25 #39321 has the usual gear case.Yours also to be a long version.
        #30101
        rapier
          Yes, it’s a long version. I wonder whether someone put an A25 powerhead on the A35/A45 leg – I’m no expert, so would that be a possible mate?
          #30103
          stanley
            I just took a look at my A25 and A35 side by side.With out actually trying it,I would say the heads would inter-change.Have you checked to make sure your rope plate serial# matches one on crankcase?The differences between the two power heads are pretty subtle.Looking at your pics I’d say yours is definitely A25 and lower unit is from A35
            #30107
            rapier
              Just checked the serial number (lip on the crankcase base, where the piston base mates to it?) and it’s B 7874; which makes no sense to me, as I thought the serial numbers of Johnsons were all numeric to 1959.
              #30109
                • This reply was modified 7 years, 4 months ago by Tubs.
                #30111
                stanley
                  The fly wheels looks to be from an A25 motor.
                  #30114
                  rapier
                    Thanks Gents, much appreciated; I never fail to learn something new here. It should be a fun project even if it’s 3 motors.
                    #30116
                    rapier
                      Pulled the cylinder off and both the piston and cylinder- updated pics.. What’s the baffle for in the port?
                      #30118
                      stanley
                        Spark arrestor in case of back fire.Some recommend removing them lest they come loose and cause damage.
