Home Forum Ask A Member AD-10 photos
  • #51599
    1946zephyr
      Darn. I sell those plates too 🙂 very common issue on the 7.5, because they were .050 aluminum.
      #51611
      drifter
        I measured mine at .033 aluminum. Hmmm. Upon closer inspection I did find another hole….but very small. I’m wondering just how much water can pass through these two tiny holes? How much pressure is there on the outside of the plate forcing water into the exhaust cavity? How little water would make such a mess in the exhaust cavity? Why only the lower cylinder? Lots of questions and few answers.
        #51640
          Well, the study of exhaust pulses is a career in itself for sure. So, don’t spend a whole lot of time trying to make sense of things that seem so unlikely. Just know that negative exhaust pulses can attract water from the most unlikely sources. And, it is surely possible to have just one cylinder "attract" the cooling leak, and that white mess is consistent with the exhaust/water spray in the manifold. You have found some holes in the inner exhaust cover, which to me, explains both problems.
          Unfortunately, it surely is possible that there are other pinhole water leaks, casting flaws, or corrosion problems adding to the leakage problem caused by the leaky inner cover. I suppose you could rig up some sort of plug to block up the water discharge from the block, then pressure test the crankcase. You would have to be very careful not to over pressurize the block overcoming the gaskets/sealer ability to seal.
          Again, this is a $20 engine. I’m thinking the inner exhaust cover is all that is wrong here, but I would surely give the block a close visual inspection prior to installing the new inner cover.
          #51784
          1946zephyr
            Acceleration is also a factor here. LOL. Just gun the engine and the waterpump pushes the water up there harder.
            #51785
            drifter
              There is a brown – varnish like – substance painted on the outside of the exhaust plate (gasket side) that I removed from my AD-10 and also on the replacement plate I’m installing.
              What is this and why is it there?
