Home Forum Ask A Member Advice on the condition of these gears
  • #4944
    gabriel
      Wondering whether these can be re-used.
      Drive Dog
      The cradle was rusted in place, so the surface where it sits is slightly rough/pitted.
      Forward Gear
      Reverse Gear
      #41762
      Steve D
        No way Gabriel, you’ll just have to scrap ’em.
        #41763
        RICHARD A. WHITE
          Paper weights….get another set…they are available…
          classicomctools@gmail.com
          #41781
          jerry-ahrens
            Agreed, those are shot. Too much is gone on the gear teeth. I would place an ad here for a NOS gear set with a new clutch dog. Or, maybe someone has a good used set. Shouldn’t be hard to find.
            #41787
              Put them up on ebay for sale as "slightly used" 🙂
              Kidding aside, lots of guys should be able to help. What are they from?
              #41801
              david-bartlett
                Great example of TOO FAR Gone!
                #41811
                gabriel
                  Okay I get it. You guys don’t have to rub it in 😉
                  quote Chris_P:
                  Put them up on ebay for sale as “slightly used” 🙂
                  They from my ’56 Johnson 10hp. I know you offered some parts to me a while back so I may contact you again if that’s okay. Although, now it seems like I practically need an entire gear case, which might end up being more cost effective.
                  #41829
                  Steve D
                    quote Gabriel:
                    Those look like they’re from the smaller gear case, ’58 and up…I might have a set. You can email me at sdpiazza@aol.com and I’ll check in the meantime.
                    #41831
                      I have a complete gear case for it call me 1 914 310 7086 Dave.
                      #42121
                      gabriel
                        So I picked up a complete gear case with new seals and a new impeller. Seller thought it was from a ’57 15hp which I don’t think exists, so I compared parts numbers for a 57′ 18hp and 56′ 15hp which all checked out fine.
                        Here it is.
                        Problem is I think there is some missing material.
                        Compared to mine.
                        The prop also seems damaged, and the hub seems off.
                        Compared to mine.
                        The props are definitely different pitches though, which I figured. (mine on the bottom)
                        Prop that came with it on.
                        My prop on. (The prop nut still fits on)
                        Any ideas what caused the damage and if its superficial? I didn’t take the prop off when I got it so I didn’t notice the damage. Seller said I could bring it back if I had any problems so not the end of the world. I could also swap all the parts over to my empty gear case.
