Home Forum Ask A Member Airguide Tachometer wire connections for 1957 Evinrude 35HP
  • #207465
    jdunham
      Hello,
      I am trying to find compatibility and wiring instructions for the vintage airguide tachometers with 50s OMC motors. the 56 and 57 30s and 35s.
      The only source that I had found for documentation looks to have closed down, classicboatworks.com.
      I couple of years ago I purchased what I thought was a 653 with sending unit and put it on a shelf. The wire connection label is missing from the sending unit and I dont want to destroy it guessing.
      Is there a resident expert or someone that has a set of instructions they would be willing to share? Maybe a pictures of the label on a 4 wire sender.
      I have exclusively 1950s OMC motors but this particular application will be for a 1957 evinrude 35.
      I am attaching pictures of what I have now. The sender has 4 wires at the back. Black, green, white, and maybe an off white. The Tach has 2 wires and 2 terminals, I assume light and tach.
      Can anyone positively identify this tach, is it really a 653? Is the sender the correct sender? I saw a post showing another 653 but it had a 5 wire sender.
      If this is the wrong one, what are the identifying features of the 653? Most of the ones I see for sale are just called out as “airguide tachometer” without a model number.
      Lastly, I know that the senders are getting rare. A few folks have mentioned efforts to reverse engineer them. Has anyone had any success yet?
      #209852
      checkmate57
        Hi, I’m not that computer savvy, so bear with me.
        #209855
        checkmate57
          I have complete instructions but find them hard to post. If this doesn’t help, maybe I can send them to you directly. Some how?
          #209863
            • This reply was modified 5 years, 7 months ago by Tubs.
            #209876
            checkmate57
              If you blow this picture up it says “ for 653 and 654 “ on the face of the tach. This is a new in box tach I’ve been saving for a upcoming project. I’ve never had the chance to use it yet
              #209878
              checkmate57
                hope something here helps
                #209883
                checkmate57
                  The last
                  #209888
                  checkmate57
                    That’s 90% of the directions in my tach box. The only thing left out is mounting information.
                    #209894
