Home Forum Ask A Member ALTITUDE & COMPRESSION READINGS
  • #3111
    Hugh Long
      O K I HAVE HINTED AT THIS QUESTION A COUPLE OF TIMES ON OTHER THREADS, BUT… I LIVE AT 4,000 ELEVATION. MY HP IS REDUCED ABOUT 12%. MOST LARGER OUTBOARDS I GET NEED TO BE REPROPED TO RUN AT FULL RPM.
      HOW ABOUT COMPRESSION TEST? I HAVE BEEN TOLD BY A COUPLE HOT ROD PEOPLE THAT IT IS AFFECTED BY ELEVATION. ANY OPINIONS? ANY CALCULATIONS? :mrgreen:
      AKA Outlaw Outboards in Fallon, Nv
      Now in Twain Harte, Ca
      #28084
      aquasonic
        That’s an interesting topic. My first thought was… "What difference does it make? It’s inside a piston and it will compress the same anywhere."
        But then I realized that the air going in is thinner and less dense, so maybe the compression would be affected.
        Improvise-Adapt-Overcome
        #28086
        SCOTT BOGUE
          It’s reasonable to expect lower compression readings, all else being held the same.
          Let’s say you have a 10:1 compression ratio. At sea level, at room temperature, you would expect to see 147 psi on the gauge.
          At 4000 feet the atmospheric pressure would be 12.7 psi at room temperature, so you would expect to see 127 on the gauge.
          #28087
          david-bartlett
            Hugh,
            A quick Google search brings up info that would support your case!
            #28102
              What auldscott said would seem to be true. Except. Compression readings on the gauge are the pressures inside the cylinder AS RELATED TO pressure outside the cylinder—–not as related to the absence of air pressure as in outer space. In other words, the gauge totally ignores the ambient or barometric pressure. It doesn’t even know what the ambient pressure is. Now if you were to put the gauge on the moon and run a long hose to the cylinder, his theory may be correct. I dunno, nobody has come up with a hose that long yet.
              Just my uneducated opinion.
              #28121
                Ok, time for someone to make a road trip! 😉
                #28125
                  When I first started reading this thread, I was thinking along Frank’s lines, having taken a just enough physics courses to be dangerous. However, what if you took the engine and compression gauge to the moon, where there is no atmosphere at all? Then what would the gauge read, when there was absolutely nothing to compress?
                  #28133
                    zero. Well actually somewhat below zero because the spring inside the gauge makes it read zero at normal atmospheric. But then it wouldn’t really matter because there is no water to run it.
                    EDIT: Reconsidering, and this is incorrect. It would read zero because, as always, it is indicating the difference between the pressure inside the gauge and the pressure outside the gauge.
                    I better shut up now.
                    #28146
                    wiscoboater
                      I believe we have a Mythbusters episode in the making here. Better hurry, I hear this is their last season.
                      #28147
                        Yeah, I don’t know why I let myself get sucked into these things. I guess I thought it was interesting to talk about. Whatever.
