I think that it is worth while to replace the lower seal on almost any motor that has not run in a long time. Every time I remove a powerhead, I find that the o-ring is hard and brittle, likely to allow water into the engine when running.
Is it worth upgrading the o-rings to quad rings in any application. On the smaller OMC engines, the seal is not restrained by the carbon carrier in the same way that it is on the bigtwin series. Would these small applications benefit from a Quad ring?
