Home Forum Ask A Member another tn27 r question… wave washer
  • #8950
      the wave washer #301855 (under the mag plate has a 1/4 inch gap in it ) circumference is broken .25 inch
      is this the way it should be or did it "crack" and open up.
      if no parts are missing from this gap I could probably just resolder it with a small piece of thin brass or copper sheet to "bridge" across the crack for more resistance to flexing and further cracking.
      thanks
      #69299
        That part number is replaced by 552029, used on lots of motors. Should be lots of them kicking around in people’s stash. I have some myself, but postage to Canada would be 20 times what the part is worth.
        #69300
          40 cents ain’t that bad 😆
          mine is not in bad shape breakage aside… i’ll try a small weld if not well I’ll get a new one
          thanks for the part #
          #69340
            🙂 well it is fixed …. I just jumped the gap with a small piece of copper soldered on and filed down to smooth any bumps
            should last another lifetime…
