Home Forum Ask A Member any opinion on 65hp Merc red band years
  • #9790
      friend looking at one
      any concerns…. wiring, impeller, carbs ,distributor or CDI ignition…I
      is this a keep away thing compression 130…all cyl
      #75149
      bob-d
        Have 3 different Mercury red bands. 4, 9.8, and a 135HP. Good years for Mercury. Parts available. Electronics can be a weak point. CDI makes replacement stators, and most likely wiring shot.
        http://www.bestboatwire.com/marine-wire … GMQAvD_BwE
        #75248
        dockbuster1
          The 4 cyl 65 from those years typically had bad spline wear If your buying it is worth checking
          #75257
          Michael Anfossi
            International Member
            Great motors as long as used in fresh water only. As mentioned by others, wires are a weak point
            #75262
              Not exactly a five minute carb job, either. If you’re an OMC guy, you won’t enjoy cleaning the carbs. Lots in the way.
              #75266
                ok rip no mercs
                what about a Suzuky DT40 mdl for 1300 $$$ cdn
                it has a whole new lower gear case??? I presume a bad collision in the past ??? dt40 looks like mid 80’s any opinions ??
                do you guys feel what I feel ???
