Home › Forum › Ask A Member › Anybody ever used Monkey Jack Evinrude fuel pump for 6hp
- This topic has 20 replies, 14 voices, and was last updated 7 years, 6 months ago by
nj-boatbuilder57.
January 1, 2018 at 2:23 pm #69144quote Bill McNamara:Larger ones don’t ship to Canada unfortunately, but have ordered the smaller one for a test. Hard to beat that price.
Same problem with the lakes up here right now, but will keep until warmer weather returns!
Thanks for the “heads-up” guys.This one ships to Canada, the price is a bit high. If you put it in your wish list, you might find the price drops from time to time.
https://www.amazon.ca/Teleflex-Marine-1 … 268+385781
January 2, 2018 at 2:09 pm #69186Thanks Westwind, have placed the item on my wish list.
I regularly shop on Amazon, but have yet to try this feature. Not sure about how "the list" works.
Is it a price alert system, or just a personal reference source?Regardless, not an outrageous price if I needed one this week.
January 2, 2018 at 2:41 pm #69187I keep things on my wish list mainly to get enough for free shipping, something I likely need later. I check from time to time for price drops, sometimes common over the winter.
January 11, 2018 at 7:54 pm #69553update….
received my cheapy fuel pump today…not bad time wise for the delivery. not like buying at the store but for $30 cdn can’t complain for now.
gave it a blow test and it works fine feels quality built but only time can tell and Spring is getting pushed back again this week-end with another 12 incher of snow coming… from the USA ๐ฎ
Joining AOMCI has priviledges ๐
January 11, 2018 at 11:12 pm #69564quote crosbyman:update….
Spring is getting pushed back again this week-end with another 12 incher of snow coming… from the USA ๐ฎWe just like to share. ๐ Melted some snow today with low 50 temps, back to twenties tomorrow.
January 12, 2018 at 5:01 pm #69583UPDATE…#2
Cheapy fuel pump perfect fit !! ๐
just needed longer bolts because of the thicker base and the cowl fit was no issue.
$60 6R74c is ready to go fishing… in May and will be retimed with Richard’s new timing tool when UPS shows up ๐
total cost
motor $60
new fuel pump … just in case $30
2 coils x $35 CDN $70
4 feet copper wire $10
2 spark plugs $10
Impeller $25
gearcasse oil $4total .. give or take $ 225 CDN $150 U$D
January 12, 2018 at 7:19 pm #69585quote crosbyman:UPDATE…#2Cheapy fuel pump perfect fit !! ๐
total cost
motor $60
2 spark plugs $10
Impeller $25
The fun and satisfaction factor on your 6 hp project… PRICELESS ๐
Robbie RobertsonAugust 29, 2018 at 6:06 pm #81975Any updates on this fuel pump? I’ve been reading some online reviews of the cheap Chinese pumps and they seem to be lacking in the durability department…
August 29, 2018 at 6:44 pm #81976they are now 14$ CDN free shippingโฆ.also
installed 2 this year & both worked fine โฆ.for how long.โฆโฆ. time will tell
August 29, 2018 at 8:53 pm #81983Since I own and operate a Marine repair shop, I’ve seen quite a few of those cheap fuel pumps. They all eventually have to be replaced with OEM, after the internals fall apart. The check valves are junk. I tried to rebuild one of the larger ones with a BRP kit, and the holes wouldn’t match up. If we are talking about a motor you plan on running very much, I’d at least buy a used OEM pump, such as on Ebay, then install a rebuild kit. That’s a better option IMO, vs. using the cheap stuff. Or, there are many good OMC NOS pumps on Ebay, that are very reasonable in price.
