Home Forum Ask A Member Anyone recognize this part? CD12? I’m lost EDIT-MORE INFO
  • #297010
    John Gragg
      Can’t remember or figure out what it is or where it goes?
      EDIT:
      A little more information and 3 more detailed pics for you all….
      After much thought (and the fact that I found this item in my box of RDE19 Parts) I think if this does belong to a motor it may well be for an RDE or RJE?
      Not that it is 100% relevant, because I can be a bit scatter-brained, but it was in a ziplock with the pin, cotter pin and washers for the carburetor solenoid link connection for the RDE.
      It is HARD plastic and definitely molded to this shape. This is not a squished something to make-due or ‘rig’ a solution. One of the pics show the ‘slot’ inside where the item would slip over on to a pretty thin (1/8″) piece of ?
      Next, all that said, my recollection is not good enough to even tell you where on the motor I “THINK” it came from.
      Lastly, I probably dreamed the whole thing – Every search of every parts guide showed nothing unless I am missing it…
      Thanks again all!
      TIA
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #297019
      aquasonic
        Maybe the rubber bushing for the bottom of the swivel tube. Part No. 58 in the attached diagram. The diagram is for a 1958 model so need to verify. Johnson Lower Unit Group Parts for 1958 5.5hp CD-15 Outboard Motor
        Improvise-Adapt-Overcome
        #297020
        outbdnut2
          Maybe someone cobbled that in to replace a bumper for mounting the shroud, or put it over a shrunk shroud bumper to cure a rattle.  Part number 77 (2 rquired) at the link below:
          https://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1957&hp=5.5&model=CD-14&manufacturer=Johnson&section=CARBURETOR+GROUP
          #297021
          John Gragg
            I’m pretty sure i would remember that.
            I’ve scoured the parts diagrams and can’t find it. Almost 100% sure it belongs on a motor, I remember fitting it where it belongs a couple of years ago, but it escapes me now.
            I also have a couple of RD 35HP and a QD15 that maybe it belongs to?
            Thx
            John Gragg
            RIverside, CA
            57 Johnson RJE-19M
            57 Johnson RDE-19
            #297022
            John Gragg
              For some reason the lower comes to mind when I look at this piece… (either CD12 or QD15?)
              THX
              John Gragg
              RIverside, CA
              57 Johnson RJE-19M
              57 Johnson RDE-19
              #297023
              Steve D
                Does not look like a stock piece I’ve ever seen from a CD, AD, QD, FD, or Evinrude equivalent. RD I’m not familiar with.
                #297024
                  Kinda’ looks like the prop nut rubber cover on a CD-12 that somehow got squished flat.
                  #297026
                  John Gragg
                    Yeah. I just finished going through every parts guide for all my motors page by page. No dice. I must have dreamed about finding the fit…
                    Gonna size it up tomorrow for a ‘squish’ review…lol
                    Thx all
                    John Gragg
                    RIverside, CA
                    57 Johnson RJE-19M
                    57 Johnson RDE-19
                    #297029
                      Very interesting indeed, what are the approximate dimensions?  Where on the engine did you find it??
                      #297032
                      aquasonic
                        On second look I see the part is on ruled paper which provides some scale. It’s much smaller than the part I referenced.
                        This makes more sense. It does look like a squashed piece of fuel line substituted for a front bumper mount. I think I see the reinforcement fibers in the cross section where it may have been cut. Maybe see if it fits on the mounting stud on the intake manifold.
