Home › Forum › Ask A Member › Automotive caps any good as a 580321 ??
- This topic has 16 replies, 6 voices, and was last updated 5 years, 3 months ago by
need2fish.
November 29, 2020 at 11:02 am #223917
tried to find the capacitance but unable to find any info
November 29, 2020 at 4:28 pm #223927I think you’d have a hard time mounting them where a 580321 goes. However, I use ones like that in Mercury/Bendix ignitions all the time.
November 29, 2020 at 5:50 pm #223931the mounting bracket could surely be cut away …. price is nice we could somehow have the uf value at 15-20$ a crack they get expensive
November 29, 2020 at 8:32 pm #223939
November 30, 2020 at 5:39 am #223956the mounting bracket could surely be cut away …. price is nice we could somehow have the uf value at 15-20$ a crack they get expensive
You don’t have to cut off the bracket. It just slides off, leaving a bare cylinder shape to try to mount.
November 30, 2020 at 8:01 am #223959
580321 are rated .22uf Having just built William Mohat ‘s caps test box I also have left over .22uf 630v small square caps which may work fine they only cost $.50 each
thay could be stuffed inside old emtied out capacitor cases squeezed a bit to make them oval shape
November 30, 2020 at 9:47 am #223963
November 30, 2020 at 10:00 am #223964tubbs… not bad $$$ in the US.. in Canada ??? I need to check it HD canada is not as parts savy as their home company
checked out napa canada they have similar caps for for 8.69 $ which is not bad
but ….if my $0.50c caps will do the job.i’ll stuff them in old caps cans in my junk box
thanks for info nonetheless
if my cheapies fail i’ll go napa …or better yet Massena NY home Depot when they open up the border crossing …one day π
This reply was modified 5 years, 3 months ago by
JACQUES.
November 30, 2020 at 2:12 pm #223980ok found/ordered 2 x dr70 T …I’ll test them out on the ” box” and measure their capacitance tomorrow. $10 each π
Car ignition capacitors seem to be going the way of dodo birds …. my NAPA had non in stock !
December 1, 2020 at 11:59 am #224037Why not go with the tried and proven Vishay axial caps from Digi-Key?
