Home Forum Ask A Member Backfiring in 1934 elto fisherman.
  • #165159
    Brenda Confer
      The engine runs very well at full speed , when I start retarding the timing it starts to backfire. any ideas or suggestions.
      #165175
      chas56x
        Try enriching the fuel air mixture.
        #165184
        Brenda Confer
          That does help but not fully illuminate the backfire; and then it does run rich.
          #165185
            • This reply was modified 5 years, 1 month ago by Tubs.
            #165217
            Brenda Confer
              This is a new condenser but I have no idea if it’s compatible with the old one. This is a battery ignition with no magneto. Thanks for your thoughts. Not sure where I could find an original condenser for this motor any ideas there?
              #165283
                #165290
                  This is the closest information I could find regarding the condenser “value”.
                  All of Tubs ideas sound good, but be careful spraying carb cleaner
                  around a hot, running engine.
