Home Forum Ask A Member Bad vibration on throttle cam.
  • #234980
    russ
      Started my QD-24 10 hp today and noticed bad vibration on throttle cam and link stop.Never seen this on any of my motors. Even the roller on cam shakey. Checked for loose components but came up empty Russ..
      #234988
        Is the mag plate bouncing around causing these other parts to shake?? Can you post a little video?
        #235026
        russ
          Was into mag plate everything is tight.Have no way of getting video.Will check over again Maybe upper crank bearing.Tganks Russ.
          #235043
            No slop in the mag plate? Either side to side, or up and down? Coils out a bit too far touching magnets?
            #235050
            russ
              Motor fired up first pull yesterday did notice a lot of shaking on throttle cam and roller also on link stop.Shut it down had a look and checked out a few things but seen nothing.Pulled flywheel checked all screws lifted on plate but no movement.Will pull mag this weekend if it warms up and check coils and a few other things. Thanks to all for the will let you know. Russ…
