Home Forum Ask A Member battery ignition
  • #276365
    beezer
      i have a 1933 evinrude fisherman that is battery ignition and was wondering if anybody has a diagram on how to wire it up? i have a coil that i’m replacing the old coil with. i did a ruddertwiw about ten years ago and it worked great but i can’t remember how to do it. thanks for any imput
      #276366
        #276374
        beezer
          thanks  i’m using a zephyr coil and was wondering does the steel laminate need to go to ground as well? do i need to run the ground wire from the laminate to the battery?
          #276375
            Your coil lam’s get a ground here but I don’t think it needs to be.
            #276387
            Monte NZ
              International Member
              Hi Beezer. I have recently made up a a coil system using a similar coil that tubs has shown and there wasn’t any earth tag on it and my one works well.
              Tubs says its not required and I agree.
