Home › Forum › Ask A Member › Battery spec
I am looking for the spec for the battery of a 1958 Evinrude 18 electric start. I know it is 12 volts but that is all. Is there a CCA requirement and or total amps for battery.
Jim Benjamin
just get a 600-750 starting battery…but even small ones 300 amps will work as long as the engine charges the battery and you don’t run it down
or… get a combo start /low discharge marine battery will also provide power to an electric kicker … best of both worlds.
Lipo4 are very powerefull and light but $$$$$
jmho
1958 18hp has no charging system.
A Walmart marine battery or equal will be fine.
Thanks to all who have helped with my question.
I suspect a good quality garden tractor battery could provide a lot of starts for this motor.
OK
