Home Forum Ask A Member Bendix/Scintilla
  • #229670
    Robert Neymeiyer
      If I was to rebuild my Bendix Scintilla condensers with capacitors, what microfarad and and voltage rating should I use?
      #229688
        Seems like I end up using some .15 mfd caps the last time I worked a a Scintilla magneto.
        If you tell us what particular motor / magneto, it may be listed in the Merctronic manual.
        mercuryspecialist
          I sent you a private message.
          Thanks,
          Joe
          #229711
          Robert Neymeiyer
            I didn’t receive a P.M.
            #229712
            Robert Neymeiyer
              I’m sorry. This ignition is on a KG7. If condensers are NLA, a member suggested I make my own out of capacitors. I just want to be certain of the microfarad and voltage rating.
              #229720
              Tom
                Search this site for more information, but there is more to it than the voltage and capacitance rating. The dV/dt is also important. See this post:
                Vishay Cap Post
                Tom
                #229731
                  Not sure if this will help or not.
                  Mercury-Coil-Condenser-specs
                  • This reply was modified 5 years, 1 month ago by Mumbles.
                  #229733
                  Steve Martin
                    There has been an excellent series of articles in the Outboarder, culminating in the January issue addressing the condenser topic. I believe all your questions are covered.
                    #229756
                      Vishay Cap Post
                      Tom
                      Thanks for posting that link Tom. After reading it, I’ve come to the conclusion I should be on Vishays payroll! ☺
                      #229816
                      Robert Neymeiyer
                        Ok, I guess I will search online libraries of articles in The Outboarder if that’s what you prefer. Thanks.
