Home Forum Ask A Member Bendix Scintilla coil
  • This topic has 10 replies, 6 voices, and was last updated 3 years ago by Tubs.
  • #257093
    Ronald Smith
      Was able to obtain a replacement coil for my Champion Blue Ribbon 1J project. Of course the replacement coil is configured differently than the original. Original had a wire out each end and the replacement has both wires out one end.
      Being new to all this, my working theory is that the 2 wires, one black and one red, constitute the primary; and the sparkplug connection ring is one side of the secondary.
      My question is how to test it. I have two meters both only have a 2K ohm setting, no 1K.  I get that I connect black to black and red to red across the primary to test it. How do I connect to test the secondary? Also, I can find no reference for expected values for this Bendix Scintilla coil.
      I get numbers on the primary, bit nothing on the secondary.
      Sorry, picture files are too large to send
      #257094
      Ronald Smith
        Took screenshots to compress pictures.
        Screenshot_20220329-070747_Gallery
        Screenshot_20220329-070754_Gallery
        • This reply was modified 4 years ago by Mumbles.
        #257097
        Tom
          To test the secondary, meter across the high tension terminal and either of the primary wires.  But if your meter only goes up to 2K ohms, you may not get a reading.  Never heard of one like that.
          T
          #257100
          Ronald Smith
            Tom,
            Sorry for the confusion.  My meter has a full range of settings.  It just doesn’t have a 1K setting. See picture.
            #257101
            Ronald Smith
              Meter picture.
              Screenshot_20220329-080040_Gallery
              #257103
              Ronald Smith
                Tom,
                Set for 20K and got a reading of 3.8 on the secondary.
                Thanks for stearing me in the right direction. Onward to getting spark. Thanks again. AOMCI is awesome.
                Ron
                #257125
                  Black is probably a common ground for both circuits and red to the points.
                  #257185
                  Ronald Smith
                    Mumbles. Thanks. Sounds right.
                    #273986
                    marksmercs
                      Hi ,Im in desparate need of 399-756 bendix coils. Is someone making them still???
                      call me 503-365-0777 pacific time  Thanks
                      #274015
                      seakaye12
                        Various posts on the site regarding Scintilla coils
                        https://www.aomci.org/forums/topic/bendix-scintilla-coil-numbers/
