Home Forum Ask A Member Bendix/ Starter Problem?
  • #243059
    ColoradoFourWheeler
      I’m just finally able to try to start the new (to me) 62 Mercury 700 and the bendix is just spinning and not engaging the engine. I’ve read this is somewhat common and that the starter may need to be disassembled and the bendix lubricated. What I’m not sure of, before I go down this path, is what direction the bendix should spin. It is currently turning counter-clockwise and about once every 10 attempt the bendix will lift to the flywheel but doesn’t actually start the motor, it lifts and then stops.
      Sounds like the starter might be bad. Any suggestions of things to try before I go that route? I’ve got 12.4 volts on my new battery and it’s rated for 550 CCA (https://www.oreillyauto.com/detail/c/marine/battery-accessories/deep-cycle—marine-batteries/220f7dcd7121/super-start-marine-battery-group-size-24/ssbb/24dcmj).
      #243070
        New battery should be around 12.5 volts, however you
        have been playing around with it some. Your Battery sounds OK.
        Could be the starter but you want to do the free stuff first.
        Disconnect the battery and clean all the connections in
        the system well. That would include the battery cable
        connection’s as well if you haven’t done them already.
        Could be just a dirty connection and the starter isn’t
        getting all 12 volts.
        #243071
        lindy46
          Counter clockwise is correct. Add a few drops of 3in1 oil and see if that helps.
          #243075
            Starter may need to be cleaned and lubed.
            #243105
            ColoradoFourWheeler
              Thank you for the suggestions. I’m topping the battery off in case it got low in the testing and I’ll go through and clean all the contacts, put a bit of 3 in 1 on the bendix and if all else fails, off it comes for a teardown. I don’t have too much choice, these starters can’t be found anywhere apparently, I’ve looked all over.
              #243148
                Call me 1 914 310 7086 Dave
