Home Forum Ask A Member Bent skegs and cavitation plates
  • #45472
    opposedtwin
      Ya Jeff, I used a simple propane torch, 2 blocks of 2 x 4 and a jorgenson pony clamp. Didn’t use a hammer at all.
      #45488
      wiscoboater
        Ok Thank you for the tips guys. I’m going to give it a shot with the clamps and hope for the best.
        #45491
          I believe someone in this club once suggested to me to heat an aluminum skeg to about 600 degrees. Since I have a temp gun, I did this to a Merc 200, auto transmission skeg, with a propane torch. It was bent out of line by as much as an inch at the bottom. I have no doubt this would have snapped off without heat, but it hammered back perfectly. Your results may vary…..
          #45600
          chinewalker
            I’ve been using the backing hammer method for years. Knock on wood, Every one has gone back to shape without breaking. Skegs and AV plates. Big hammer on back side, strike front side with smaller hammer, inline with backing hammer. Repeat. A lot. Some thicker skegs will take some effort.
            #45602
              I have been successful using heat and gentle pressure little by little on a press.
              Respectfully
              #45621
              PM T2
                Skeg? cavitation plates? what’s them? My favourite motors don’t have ’em……..
