Home Forum Ask A Member best practice for cleaning mixture needle packing nut material
  • #300056
    GUY SCHMIDT
      I’m struggling with black stubborn packing nut material in a carb I’m rebuilding. Trying to mechanically remove the old packing
      and not having much luck. Then I realized there must be some experienced lads out there that might share a tried and true method
      or particular solvent that dissolves these things. I look forward to your comments…..Guy Schmidt
      #300057
        When rebuilding my carbs, I usually either soak them in a gallon bucket of Berryman’s Chem-Dip carb cleaner or soak them in hot water in a kitchen crock-pot.   Either method seems to soften the packing material so you can get them out with a small pick tool.
        1982 Evinrude 25hp
        #300073
          Very interesting topic indeed.  I oftentimes skip trying to pull out the old packing for fear of introducing debris into the mixing pocket, usually just add fresh packing over the old stuff…   Will definitely try Bob’s suggestion during my next hot ultrasonic cleaning though
          #300076
          GUY SCHMIDT
            Great Bob, I’m going to try one or both of those techniques today!
            #300077
            GUY SCHMIDT
              Hey Fleetwin, thank you also. Since my carb is off the engine I’m going with replacement. But, under other
              situations I might try your suggestion.
              #300080
                A hot ultrasonic soak would likely be the best solution.  I don’t have an ultrasonic so my hot crock-pot method was my alternative!
                1982 Evinrude 25hp
