Home Forum Ask A Member brass fitting for gas lines on TD-20 Johnson outboard
  • #6226
    td20
      copper gas lines with brass fitting
      The brass fitting for my 3/16 copper gas lines are very difficult to work with. I viewed a video on YouTube about joining compression fitting and my fitting don’t work that way at all. My fitting are very tight, like the threads are mismatched. Do these fitting have some type of special threads ? Do these fitting have a short life for loosening and tightening them ?? I used 3/16 inch nuts and compression sleeves from AutoZone.
      #52123
      RICHARD A. WHITE
        Do you have pictures of the fitting(s)
        classicomctools@gmail.com
        #52126
          Compression fittings should be easy to take apart and reassemble. But if you are talking about the tapered pipe threads, like where it screws into the tank, yes they are designed to wedge together tightly, and generally also need a sealer.
          Yes, compression fittings do wear from repeated disassembly and retightening. It is the sleeve that wears. You can see the groove at each end of the sleeve. Some grooving is normal (the "compression" in the description). But deep mashing of the ends of the sleeve is not good. Overtightening, even at the first time of assembly will also mash them and ruin them.
          https://en.wikipedia.org/wiki/Compression_fitting
          #52856
          drdipstick
            I have just restored 2 TD-20’s and took apart 6 parts motors to accumulate a good supply of usable parts to do the work. I have several of these copper lines and will be glad to send you one. Have other parts available including some good coils.
            Dick Rheutan
