Home Forum Ask A Member British Silver Seagull
  • #2648
    burt
      Raised an outboard rack this pm to accommodate this Seagull, and noticed the port-to-starboard swivel is very stiff. Looked but see no nut/bolt to tighten or loosen. Where is the tension adjustment on these? Is there a lock-down for the motor, like the Mercs and OMC’s I am used to? Thanks in advance.
      #24744
      ausob-collector
        There is no swivel tension adjuster as such. If you remove the fitting that holds the driveshaft tube to the mounting bracket, you should be able to clean and lubricate and that should help.
        Get on to Saving Old Seagulls for more in depth information.
        Cheers
        BP
        #24757
        burt
          Thanks, I’ll give it a shot.
