Home Forum Ask A Member Brought home a Ruddertwin
  • #49569
    slim60
      There is no stamp on mine either (1922) but there is an 824 on the steering bracket. Any help? And no exhaust gaskets. Did they use any? If so what kind? Thanks
      #49571
      Tom
        Is the tank mounted to the motor? , or is it loose and out of place? I’ don’t recall a Ruddertwin with the flywheel hanging over the front of the tank.
        Tom
        #49582
          quote Slim60:
          There weren’t any exhaust gaskets on my motor
          when I took it apart either.
          Don’t know if should have.
          I’ll probably make some.
          #49583
          Tom
            Fitting the exhaust manifold on a Ruddertwin has been problematic for me every time, from the A to the J. And that includes motors I knew to be all original, not a mix of parts from different motors.
            Most of the ones I’ve worked on had some kind of gasket in all three manifold openings. I had to use material of different thicknesses to get the screw holes to line up in the manifold, leg, and cylinders. Be patient, and try not to enlarge the screw holes in the manifold to get it to fit. Keep the cylinder bolts loose until you’ve got the manifold lined up with everything, so you can rotate the cylinders a bit. You may even have to adjust the thickness of the gaskets used at the base of the cylinders to get the screw holes to line up with the manifold. Best to dry fit all of this before you use any sealer, if that’s what you plan to do. The cylinder gaskets can probably just be greased. But if you use any kind of paper for the manifold, you’ll probably need some kind of sealer to keep them from blowing out.
            Tom
            #49609
            slim60
              Thanks Tom; Paper and sealer it is.
