Home › Forum › Ask A Member › Big twin service bulletin
- This topic has 4 replies, 4 voices, and was last updated 5 years ago by
Don.
February 28, 2021 at 7:25 pm #232542
I think I remember hearing about a service bulletin for the 25hp big twins, something regarding the cooling and putting a pinhole in the water tube to cool something.
Anybody have this bulletin or the bulletin number?
Thanks,
RJ-
This topic was modified 5 years ago by
trex014.
March 3, 2021 at 1:38 am #232732I remember a service bulletin from the sixties regarding drilling holes for cooling on the 40hp.I will not have accses to my bulletins until spring.
March 3, 2021 at 9:25 am #232735Here is a previous thread regarding drilling holes in the Big Twin motors:
https://www.aomci.org/forums/topic/rde-18-powerhead-to-exhaust-plate-gaskets/
"Every time you remove a broken or seized bolt an angel gets his wings."March 3, 2021 at 1:54 pm #232880Bob, I’m familiar with that thread and checked it over again but I’m looking for info about drilling a hole in the copper water tube itself, I think I remember it being a 1/16″ hole but I’m not sure where it is supposed to be on the tube and what it’s supposed to cool. I’m 99% sure it was for the mid-late 50’s big twins but maybe I am thinking of the 40hp bulletin.
March 4, 2021 at 6:12 pm #232938We have had a similar discussion regarding 15/18hps that seemed to have hot exhaust housings. We found that there was a relief hole from the lower cylinder cooling jacket that sprays into the exhaust housing. Oftentimes these cooling relief passages get plugged up with carbon. I’m wondering if your Bigtwin has a similar relief hole…Wish I had a crankcase around to check, but do not… I would prefer having the relief hole coming from the block, then reducing cooling water pressure by drilling into the inlet cooling tube. I will try to find a picture of this relief hole on the smaller engines and post it for you…………Don
