Home Forum Ask A Member caille rbm
  • #9250
    gofastgramps
      I am working on a Caille r.b.m. I noticed there is no plug in the lower unit for grease. it looks like I have to dissemble the lu each time to grease it?
      does anyone have any tricks on greasing one?
      #71229
      PM T2
        take the water pump out. You don’t have to disconnect the hose, and there’s only one screw holding the pump in.
        Hope it helps.
        Best,
        PM T2
        #71371
        gofastgramps
          Thanks for the reply.
          that would work for the water pump part but I cant see how the grease to get to the gear cavity.
          gary
          #71377
          PM T2
            You’d have to pump enough in there to force it back there. If you have a flexible hose on the end of a grease gun, you could do it that way.
            But – if you’re not comfortable with that, the only other alternative is to remove the propeller and rear cap, and fill the gear cavity in directly.
            Is it a standard prop, or variable pitch?
            Best,
            PM T2
            #71413
            gofastgramps
              variable pitch. I was tempted to drill and tap for a pipe plug.
