Home › Forum › Ask A Member › Cam follower drops behind the cam CD11
- This topic has 5 replies, 2 voices, and was last updated 4 years, 1 month ago by
JACQUES.
February 5, 2022 at 11:30 am #254028
I did something wrong…
upon reassembling by Cd11 cam mag plate etc… I ended up with my cam follower going behind the cam and making it impossible to turn the throttle handle beyond STOP on the next attempt to go start and fast.
the cam under the mag plate hooks over the cam follower instead of pushing it outwards to open the throttle plate
I did not alter the teeth on the throttle handle where it meshes with the engine side. so obviously the problem is above
where did I goof ? coud I have mounted the cam in a wrong set of bolt holes under the mag plate ?
thanks
February 5, 2022 at 11:41 am #254031Sounds like you installed the magneto plate and didn’t make sure the cam follower on the carb was pushed forward to clear the cam. Pull the mag plate back off and push the cam follower forward as you re-install the mag plate. Also, when you install the mag plate, turn it so the small end of the cam is pointing forward – the follower will then be in front of the cam. See enclosed pic from my CD-11 assembly.
"Every time you remove a broken or seized bolt an angel gets his wings."February 5, 2022 at 11:47 am #254035See corrected pic showing cam follower.
"Every time you remove a broken or seized bolt an angel gets his wings."February 5, 2022 at 12:10 pm #254040OK thanks guess that is what happens when one installs the carb AFTER the mag plate and cam 🙁 doing the carb first would have made this obvious when reinstalling the mag plate
i’ll pull everything and reset
February 5, 2022 at 4:22 pm #254070update:
looks like the little sleeve I added over the worn (50%) cam follower became the problem because the cam had trouble sliding itself behind the cam follower to push it up from STOP to SLOW to START mode position.
the cam was knocking against the sleeve rather than sliding behind it to open the throttle plate. the cam just needed to be a bit thinner at the low side so I just rehapped the end tip to compensate for the new sleeve thickness…
it was not much but the sleeve messed up the cam to cam follower ” relationship” 🙂
February 7, 2022 at 8:19 am #254185update…. a silly issue really … problem was really the carb linkage to cam follower not installed when the issue came up
reinstalling the carb links prevented the cam follower from being pulled to far back by the return spring and stopped it from being hit by the cam’s right side leading edge .
with links in….. the cam has no problem going behind the cam follower & pushing the it to open the throttle plate
clear as mud ?
