Home Forum Ask A Member Can this cylinder be repaired
  • #273230
      Joe
      My question about matching the intake port
      to the sleeve are answered by knowing their
      depth and the lines you have drawn on the
      on the cylinder. Your pictures were really
      helpful to me in understand how you
      accomplish that. Thanks for posting them.
      #273232
        JoeCB, that’s some “Out of the Box” fixturing!
        I presume the cutter was for cutting out the ports
        in the sleeve……. not sure how you located the
        precise locations to cut though.
        HARRY D. NICHOLSON
          George E:  Thanks for that idea, which I will perform if alignment is off, after first practising drill/cotter fit on scrap.  On a side note, the piston rings are the same size as Model A Johnsons except for a locating notch to file in one edge.  On Jack Craibs Caille web site there is a brochure on the slow trolling attachment for the Liberty Twin which is very unique and interesting, and I’ve never seen one in person
          #273306
          JOSEPH BRINCAT
            And , “the rest of the story” …..Just in case you are considering going this way.    I found the receipt for the sleeve from LA Sleeve,  $ 82.00 with shipping.
            #273338
            HARRY D. NICHOLSON
              It appears that 2 cylinders are in the process of disassembly for delivery at this time.
              #273339
              dmbono
                Hi Joe
                Is that a South Bend heavy ten lathe? Looks to be in good shape.
                JOSEPH BRINCAT
                  The lathe is a SB 13″ , the big brother of the heavy 10.  I bought it about 40 years ago from the salvage department at Cadillac Motor Car, here in Detroit where I spent 35 years. Back in those days, before we were overrun by lawyers, the company had an employe salvage sales department. About anything going out could be purchased for the salvage value, including blemished (new) tires, past model stuff like upholstery material, floor matt sets and 5 gallon cans of lacquer paint. Not any more, all that sort of stuff goes to the landfill.
                  #273341
                  JOSEPH BRINCAT
                    Harry, look at those cylinders closely. I know that there were two styles, there is a significient difference in the port sizes, between older and newer models.
                    Joe
                    #273368
                    HARRY D. NICHOLSON
                      Thanks joe.  I’ll take my old ones along to compare when I pick them up locally at the sellers house. I finished tightening up the rods today.  One was very loose on the crank end. Prior to disassembly, when looking at the pistons through the exhaust ports, one piston would not move when starting to turn the crank, while the other piston moved immediately. Seems odd that only one rod was so worn. The oil holes in the small end of both rods were plugged with carbon. Holes in both ends are 3/32″ dia. Maybe the plugged holes should be drilled larger ?
